Home > Technical > immobiliser Issue off road |
Redlinemike Member Since: 27 Oct 2013 Location: Frozen north, Just off the M8 Posts: 93 |
i had this issue before with my td5 competition vehicle when it was first built, heavy landings or jarring would cause the exact symptoms you describe,
in the end the only way i found stopped it was by removing the 10AS unit totally & de imobilising the vehicle, i found even with the flasher relay removed it still did it 110 XS DC M57 + 8 Speed auto ORA jeep- Sold Tomcat 88 |
17th Oct 2015 10:46am |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 |
The alarm/central locking unit has an impact sensor, the purpose of which is to unlock the doors and activate the hazard flashers in the event of an accident.
18th Oct 2015 10:48am |
LittleFoot Member Since: 25 Aug 2012 Location: east sussex Posts: 233 |
Gents,
Thanks for your advice. Seems most likely that it's the impact sensor inside as you mentioned. Have tried reseting by switching ignition off and then on again. Then off for 10 mins. For heavy offroading will need to investigate options. Cheers |
18th Oct 2015 11:42am |
