Home > Maintenance & Modifications > RedBooster Clutch Servo |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Sounds like rubbish to me, all it does is make the clutch lighter by providing vacuum assistance the same way your brake system does.
I have no experience of one as I love my heavy clutch but I see no reason why it should wear your clutch out any quicker unless you slip it more due to it being lighter in operation? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
12th Oct 2015 12:37pm |
Ranger Member Since: 17 Nov 2011 Location: United Kingdom Posts: 75 |
12th Oct 2015 2:48pm |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
What's the "spring mod" that's talked about in that thread?
13th Oct 2015 1:43pm |
You can change the clutch spring for a Td5 clutch spring which is much lighter than the older style Tdi clutch spring.
Have a look at your clutch peddle, if it has a long tubular spring coming down from a bolt to your peddle, you should be able to change it, if you don't then you probably already have the lighter version. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
13th Oct 2015 8:04pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
We've sold several Red Booster kits and only had good feedback.
We had one on our TD5 tray back and it made winch challenges a lot easier on the left leg |
13th Oct 2015 9:11pm |
JustStarting Member Since: 02 Sep 2014 Location: Dorset Posts: 146 |
Hi Arsath
I have just had a Redbooster fitted on a TD5 Twincab that I use for off roading I cannot praise it enough, the clutch is so light that after a full day off roading instead of my leg being tight and tired it was absolutely fine. I have to admit that you need to get used to it and that you cannot rest your foot on the clutch at all else it will ride the clutch and slip It took me a day to get used to it and it is money well spent. Not sure I would fit it to my Puma but a definite for the tdi and td5 MY2015 110 Urban Truck Expedition Spec 2005 Td5 TwinCab 1998 110 CSW 300tdi |
19th Oct 2015 10:30pm |
Arsath Member Since: 20 May 2015 Location: Sri Lanka Posts: 133 |
Thank you all for your valuable feedback.. I think I will do this upgrade..
22nd Oct 2015 12:18pm |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
I had looked into it but the cost for the unit plus for the install costs made it cost prohibitive for me and so just got used to the clutch and invested the money on other land needs.
22nd Oct 2015 12:44pm |
