Home > Maintenance & Modifications > Can you ID the bolt?!
Northernremedy
United Kingdom 2004 Defender 110 Td5 CSW Aintree Green
Hello! So, turns out these two bolts (one very rusty one not), are somewhat loose, i think that the rusty one may be where the moisture is coming through in to the footwell - sound likely?
Can any point me in the right direction for SS replacement for these?
Thanks in advance!
Anthony
Ps photo to follow pc being a pain
Post #462310 11th Oct 2015 5:52pm
Northernremedy
Post #462311 11th Oct 2015 5:53pm
bob neville
http://www.a2stainless.co.uk/Land-Rover-De...ARZ9M.aspx
2013 Defender 90 CSW - sold
Post #462323 11th Oct 2015 6:18pm
Northernremedy
You're the man thanks!
Post #462326 11th Oct 2015 6:36pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Moisture in the footwell probably a combination of things - have you noticed how much ends up in there from the roof gutter every time you open the door when it's raining? No doubt someone will prove me wrong, but I'd say damp foot wells were just a sideline of owning a Defender. Glad I've just got mats and not carpets.
Post #462328 11th Oct 2015 6:42pm
Screbble
Re: Can you ID the bolt?!
Thanks in advance!
Anthony
Definitely something you should get used to Rolling with laughter
I agree on the roof gutter problems - and not always/just when the door is open! Laughing
Also have a closer look at the faux windscreen hinges (gaskets) and the horizontal seal. Thumbs Up
Post #464823 19th Oct 2015 11:00pm
If you replace one of those with SS make sure you use corrosion block / corrosion prevention paste
Post #464825 19th Oct 2015 11:08pm
Northernremedy
Cheers gang! Think some moisture may be coming down through the door. The door bottoms aren't looking in their first flush of youth.
Nipped the bolts up and they took so wil replace at some point!
Post #464866 20th Oct 2015 8:37am
