Home > Off Topic > V5 under special notes says Registration none transferable.
Stacey007
Hello
Never noticed this on any other car, but in the special notes on the front of the V5 it says Registration none transferable.
Can I put my own private number plate on though?
ooh and hello, I could soon be a new 110 owner Smile
Post #458034 25th Sep 2015 6:45pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Is the plate on it currently an old plate? The DVLA sometimes do this to stop you from transferring an old (and valuable) plate from your car onto retention, forcing the DVLA to issue you another age related (and valuable plate)
You can place another plate onto your vehicle, but the plate currently on it will not be able to be transferred onto another vehicle. Chance are, when you remove your plate in the fututre, the same plate thats on it now, will be re-allocated to it.
Post #458042 25th Sep 2015 7:11pm
That is normal if for example an original registration has been reissued. My 1952 Bedford OLBD and my 1961 Iron Fairy 6 both were annotated thus after I had the original registrations reissued to replace the ghastly "SU" and "Q" plates they had respectively when I bought them.
As far as I know you can still put your own plate on the vehicle if that's what floats your boat but you can't put the plate currently on the vehicle on anything else.
Post #458043 25th Sep 2015 7:13pm
Stacey007
Hello
No the plate on the LR is nothing special at all, that's why I thought odd just a normal plate that reads nothing I can make out and not old it the newer format such as AB 64 XXX
odd but as long as I can put my private on it that's all good
Post #458044 25th Sep 2015 7:15pm
ARC99
If I remember correctly, you cannot use a VRM to make a vehicle appear younger so your 64 plate could not be put on a 2015 vehicle. Don't make old people mad.
Richard
Post #458045 25th Sep 2015 7:18pm
Other way around, you can't put the 64 plate on anything older Thumbs Up
Post #458073 25th Sep 2015 9:05pm
Stacey007
Hello
Thanks, it was more the issue that the LR has the note on the V5 and I thought this means you cannot put a private on it.
so None transferable plate simply means the LR plate will always stay with the car no matter what other plates may go on the car over its life.
Post #458075 25th Sep 2015 9:17pm
Sort of but more importantly it means the non transferable plate can't be put on another vehicle
Post #458087 25th Sep 2015 10:09pm
Stacey007
Hello
Update....
I have the V5 back for the LR now with my plate on so all is good on that front. Oddly, under the special notes now it does NOT say the registration is none transferable? I guess that's as now I have my plate on it...
All very confusing... but at the end of the day all worked out.
Collecting it Sunday Smile
Post #459797 2nd Oct 2015 11:59am
That itsn't odd at all.
As explained above, the note meant that the non-transferable plate that was on the vehicle and to which the note applied could not be transferred to and displayed on another vehicle.
Now that you have your vanity plate on the vehicle, the note is irrelevant and has gone. If it was still there, you'd never be able to use your vanity plate on any other vehicle in the future.
Simple, really!
Post #459802 2nd Oct 2015 12:25pm
jst
i expect the vehicle you bought previously has a private plate on it so a 2nd age related one was put on it prior to you buying, hence the non transferabble 2nd number. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #459811 2nd Oct 2015 12:57pm
Stacey007
Yep both right Smile
I like it 'Vanity plate'
will match my Vanity wheels and other bits I guess Thumbs Up
Post #459829 2nd Oct 2015 2:12pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
This is to stop people making money from the DVLA issuing age related plates. e.g. you have a classic car with a (potentially valuable) old plate then put a private plate on it. You sell the original plate. Then you take the private plate off the vehicle and the DVLA issue a new age related plate, you then sell the new (potentially valuable) age related plate and put back the private plate and so on. Making the age related plate non-transferable puts a stop to this.
Post #460802 5th Oct 2015 9:34pm
