Home > Wheels & Tyres > tyre pressure |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2525 |
Hi
I am running mine at 35 psi Cheers Mark |
9th Sep 2010 9:54am |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 |
Handbook states 30psi front/48psi rear for my 110, but I find 28psi front/38psi rear greatly improves ride quality. No uneven wear/other issues after 15kkm.
9th Sep 2010 12:49pm |
landy Member Since: 29 Aug 2010 Location: cheshire Posts: 34 |
cheers think i will try 30 front 35 back
10th Sep 2010 8:53am |
cannonball my log book says 28psi front 38psi rear so i have put this in and it drives awesome cheers
10th Sep 2010 2:03pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
you must remember the bigger the tyre the less PSI you need NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
10th Sep 2010 2:44pm |
David128 Member Since: 31 Jan 2010 Location: Melbourne Posts: 30 |
BF goodrich should be able to recommend tyre pressures for you if you give them the axle weights. They should also be able to give you pressures for off road work at lower speeds and maximum flotation. |
21st Sep 2010 1:14pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
Do that as its NOT the same as the LR book figure and tyre fitters dont always know/care The disco pressures from bfg were different - significantly Mike |
21st Sep 2010 9:30pm |
Don't forget that weight makes a lot off difference.
I use the same BFG MT's first under my Camel Disco 2500 KG and now under my 90 TD5. Off road I let them down to 1.3 bar. With my Camel they were really soft specially if I had to drive a small length on the road. With my 90 I think I have to defalte them further as they didn't feel soft on the road for about 1 km to get to the petrol station to inflate them again. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
22nd Sep 2010 1:47am |
