Forum · Gallery · Sponsors
Home > Maintenance & Modifications > Improving Turning Circle
Reply to topic  Down to end
CFB
2008 Defender 110 Puma 2.4 XS CSW Manual Stornoway Grey
Which is the best way to improve the poor turning circle on the 110 CSW?
I'm led to believe the options are wheel spacers (seem expensive at around £200) or change the alloys for ZU or similar with bigger offset?
Any experiences folks?
_________________
Andy
110 2.4d XS CSW
Post #2638 6th Jul 2008 9:49pm
AndrewS
United Kingdom 2007 Defender 110 Puma 2.4 DCPU Manual Alveston Red
Or simply wind the stops in a bit
Post #2646 7th Jul 2008 9:55am
TJ101
2007 Defender 110 Puma 2.4 XS CSW Manual Cairns Blue
Yep, worked for me,, certainly better !!
_________________
RRS G4, V70R, 90 V8 Hybrid
www.wessex4x4response.org.uk
Post #2648 7th Jul 2008 10:38am
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Manual Stornoway Grey
So with standard wheels and tyres, how many turns would be considered safe? And roughly what radial turning-circle distance reduction equates to a full turn?
_________________
2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #2649 7th Jul 2008 11:03am
CFB
Daft question then, why set the stops that far out in the first place? I would have thought they would be set up to give maximum turning without rubbing Confused
_________________
Andy
110 2.4d XS CSW
Post #2650 7th Jul 2008 12:04pm
AndrewS
That is the million dollar question and I don't know the answer.
It would have been set at the factory to allow the wheels to turn but not go too far as I presume damage to the CV joints would occur at full lock +
Post #2655 7th Jul 2008 4:46pm
Chaser
Australia 2007 Defender 110 Puma 2.4 SW Manual Alpine White
HI guys
I am not sure where you would wind out to fix this problem?
anyone with photos?
thanks
_________________
if it moves shoot it, if it dosn't push it.
Post #3351 28th Aug 2008 9:21am
View user's profile Send private message Send e-mail Reply with quote
bell-auto-services
Site Sponsor
The stops are there partly to restrict movement of the CV joint and prolong the life of the joint barings.
And at the same time prevent tyre rub.
Regards Pete
_________________
www.bellautoservices.co.uk/index.php
Post #3388 28th Aug 2008 4:09pm
mse
2008 Defender 90 Puma 2.4 XS CSW Manual Java Black
So whats the answer on this.
I took the 90 round the Mcdonalds drive through and had to shunt on full lock to get to the window - surely that isnt correct?
_________________
Mike
2.4TDCi 90CWS XS
300TDi Discovery
Post #3397 28th Aug 2008 4:43pm
bell-auto-services
Site Sponsor
Here is how
Regards Pete
www.bellautoservices.co.uk/Defender-Steering-lock-adjustment.pdf
If someone can upload direct to the forum then please do so other wise ill leave on my server.
_________________
Post #3400 28th Aug 2008 5:18pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Manual Zermatt Silver
Thanks Pete, just the information!
_________________
110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #3424 29th Aug 2008 6:56am
Reply to topic  Back to top
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2008 Martin Lewis
