Home > Maintenance & Modifications > Dinitrol RC800 question |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 |
just this weekend finished a full (my first) Dinitrol job...
recommend watching the Funrover video on the Dinitrol website, explains it all well. RC800 is a rust treatment and part of the prep, it's not really a 'finish' - you need to go over with it with the cavity wax / underbody wax for a proper finish. Just one or two coats does the business. The RC900, which is apparently similar to RC800 except in an aerosol, it's designed for cavity areas but leaves a clear shiny hard finish, might be good for short term touching up of rusty bits but ultimately probably needs a top coat. |
6th Sep 2015 7:44pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
I use rc900 as a rust converting primer. Then top coat with something else.
6th Sep 2015 9:43pm |
