Home > Td5 > Clutch? Or something else? |
Simple things first, is the fluid level ok? 2002 90 Td5 Station Wagon
5th Sep 2015 12:31am |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 |
Grafty99 thanks for your answer
bloody bone dry? Makes sense and should have checked that first, but obviously have a leak, popping out to buy some now. Keith 2005 TD5 90 CSW XS |
5th Sep 2015 8:30am |
The slave cylinder could be leaking? Also check that the hydraulic pipe is dry and that there is no fluid dripping from the bell housing 2002 90 Td5 Station Wagon
5th Sep 2015 8:33am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2203 |
Whip the two 13mm bolts out and pull the slave cylinder out. My money is on it being very wet around the end.
Would advise also changing the master at the same time. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
5th Sep 2015 11:17am |
