Home > Technical > Best way to remove these? |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1778 |
Click image to enlarge Click image to enlarge As you can see, the screws are beyond unscrewing so wondering if should drill them out, like rivets? Sorry for the very amateur question |
2nd Sep 2015 9:14pm |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
+1
2nd Sep 2015 9:19pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
If your going to cut them off and grip them (which you probebly will do) you may as well try with a good fitting screwdriver first.
You may be surprised, mine were very similar when I first got mine but with good pressure on it it may yet wind out. If not, mole grips and swearwords I'm afraid Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
2nd Sep 2015 9:23pm |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3615 |
you could try dremelling a slot for a flat blade screw driver worked for me in the past DEFENDER 90 TDCI XS,
2nd Sep 2015 9:41pm |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 405 |
3lb club hammer. Works every time!
But watch your fingers. |
2nd Sep 2015 9:52pm |
