Home > Maintenance & Modifications > No Stop Lights |
It might be worth unplugging the trailer electrics loom, mine had a weird fault where the drivers side indicator came on permanently due to corrosion in the plug 2002 90 Td5 Station Wagon
2nd Sep 2015 8:33pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1747 |
bulbs correct way round ???
2nd Sep 2015 8:40pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
Might be a good shout, as she's now semi retired, I havn't towed anything for a while George Ta
@Roma....not changed or altered anything, just drove it |
2nd Sep 2015 8:50pm |
disconnecting towing socket hasn't worked
2nd Sep 2015 9:19pm |
Rich broom Member Since: 26 Jul 2015 Location: Tiverton Posts: 78 |
My bet is you have a single filament sidelight bulb instead of a twin stop tail.
Sounds like halfords have been at it |
2nd Sep 2015 9:21pm |
Unless someone's swapped my bulbs, that can't of happened 👍
2nd Sep 2015 9:36pm |
Too much bass? 2002 90 Td5 Station Wagon
2nd Sep 2015 10:09pm |
could be I'll have another prod in the morning supposed to be heading back down your way tomorrow
2nd Sep 2015 10:30pm |
Take the puma 2002 90 Td5 Station Wagon
2nd Sep 2015 11:00pm |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
Sounds like a short somewhere i.e. bare wire rubbing perhaps. Jeff
3rd Sep 2015 8:29am |
check the fuses Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
3rd Sep 2015 8:39am |
sorted
It was an open circuit caused by the 2 terminals touching in the o\s stop/tail bulb holder. Thanks for all the replies, hope it can help someone else out George ........... NO You'll hear the purr of the TD5 pass later |
3rd Sep 2015 9:11am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16896 |
I'm thinking an open circuit on the earth connection between the rear lights and the chassis.
If you turn on the sidelights and brake while the sidelights are on, do the lights all go out? EDIT - my post made simultaneously with the one above. |
3rd Sep 2015 9:17am |
Cheers Blackwolf, I was hoping you or K9 read this last night It was quite a simple fix for a change The symptoms where the exact opposite, ie no lights apply brake = all lights on, and when lights, on brake lights permanently illuminated, apply the brake had no effect. I was thinking broken wire/rubbed through
3rd Sep 2015 9:46am |
