Home > Technical > 3 squeaks after engine turn off |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3615 |
egr valve self clean , mine is an 11 and has done it from new, I sort of find it reassuring that everything is fine. getting more noisy may be an issue with debris build up, lots of threads on here about it. DEFENDER 90 TDCI XS,
30th Aug 2015 8:46am |
MrOl Member Since: 21 May 2015 Location: East Anglia Posts: 41 |
Does it matter that it has suddenly got a lot louder doing it?
30th Aug 2015 9:54am |
get your head under the bonnet whilst someone else switches it off and try and isolate exactly where the sound is coming from.
Better still video it and pop it up on here for a better diagnosis. |
30th Aug 2015 10:22am |
Have video - will upload in the morning when internet faster. Having listened again, it is doing it occasionally as engine revs up or down....it sounds a bit like a belt slipping perhaps? Hopefully video will enable someone to diagnose it.
30th Aug 2015 8:11pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19579 |
I have known the EGR to make noises durning running occasionally.
Usually when they are about to cause you problems. I'm glad I'm rid of the damned thing personally but most of us can probably tell if that is it or not if you upload a video like you said, |
30th Aug 2015 8:26pm |
So got there eventually with the video...hopefully this works:
http://vid791.photobucket.com/albums/yy200/mrol/IMG_3002_1.mp4 sound is at 4s, then at 20-24s and then finally at 33s when engine is being turned off. It doesn't do the creak/squeak quite so much at turn off this time (i.e. each 'pulse' of the EGR cleaning it doesn't creak on the video, but sometimes it does do it with each pulse). |
31st Aug 2015 5:43pm |
Yup egr valve, all my 2.4's made the chukka chukka sounds at shutdown from new, yours sounds noisier in operation though. Plenty of threads on here about it, the search function should reveal them. Steve.
31st Aug 2015 6:25pm |
So should I get it checked/cleaned/replaced or is it ok to run with it?
31st Aug 2015 7:38pm |
Yes that sounds a bit painful mine is a smoother sound and quite quick. also can only be heard on shut down DEFENDER 90 TDCI XS,
31st Aug 2015 8:25pm |
Try some Millers Diesel additive for now, see if it improves.
31st Aug 2015 8:58pm |
Would the brand of fuel have any bearing here?
31st Aug 2015 10:07pm |
It can add to it yes, generally most of us use BP, Shell or Esso.
Not any supermarket brands. |
31st Aug 2015 11:08pm |
Penguin Member Since: 08 Dec 2014 Location: Tienen Posts: 247 |
1st Sep 2015 6:39am |
Wombat2 Member Since: 07 Nov 2011 Location: Cheshire Posts: 5 |
Mine has been replaced 3 times in four years!
1st Sep 2015 11:00pm |
