Home > Puma (Tdci) > Charging fault?
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Charging fault?
Hi!
I am stuck in Almaty, Kazachstan with faulty clutch slave cylinder.
Today it was replaced with new one at LR dealer but just after leaving I have realised my charging voltage occassionally dropping to 12v,illuminating the battery dash light.
Is it the generator fault or they may screw something while changng the slave cylinder?
Its 8pm here, tomorrow they continue. Any hints?
Janusz Janusz
www.yahodeville.com
Post #448456 23rd Aug 2015 2:53pm
K9F
I presume they may have isolated the battery whilst working on it? Check the connections. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #448492 23rd Aug 2015 6:00pm
yaho
Thank you for the hints. In the meantime I have swapped the generator but the problem persists.
Today I have crossed to Kyrgystan and noticed the voltage drops only on bumps, sometimes causing the stereo to restart. Jumped under the vehicle, ground cable seems to be firmly fixed to the gearbox. Where shall I look next?
Cheers! Janusz
www.yahodeville.com
Post #449104 25th Aug 2015 4:50pm
K9F
Battery connectors, starter motor and alternator connections would be my next ports of call. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #449114 25th Aug 2015 5:28pm
yaho
Thanks again. I will check it. How serious the problem is? Can I continue for e.g. next 1000 km losing charge from time to time? Yesterday I did 300 km, the battery light went on only once, I can see on IBS both batteries are fully charged.
Cheers! Janusz
www.yahodeville.com
Post #449267 26th Aug 2015 4:24am
yaho
Cheers! Janusz
www.yahodeville.com
Post #449268 26th Aug 2015 4:30am
yaho
Fixed. Fuel line bracket was rubbing power cables.
Cheers from Uzbekistan! Janusz
www.yahodeville.com
Post #452074 4th Sep 2015 8:59am
