Home > Maintenance & Modifications > Cleaning chassis internally question. |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
That's exactly what I do with mine, there are a few obstructions along the way, mostly reinforcing tubes going across at important mounting points, but pulling the hose back a couple of inches while twisting it will normally clear most of them.
I find it easiest to go in through the large hole at the back just in front of the rear crossmember, that will get probably up to the centre crossmember, then from just behind the bulkhead outrigger both forwards and back towards the rear. |
30th Jul 2015 8:09am |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2015 |
Does much crud come out? 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
30th Jul 2015 11:48am |
I got quite a fair bit of mud and small stones out of mine, I guess it depends where you've been though.
30th Jul 2015 1:25pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
tried doing this with mine a couple of years ago. didnt work. the jet wash line got caught up about 3 foot into the chassis. again going from the front back. i was using a nilfisk pressure washer and their drain rodding attachment.
30th Jul 2015 2:00pm |
I use the Karcher one similar to this -
https://www.karcheroutlet.co.uk/products/product.asp?id=2227 The "business end" is only about 20mm across and will get to most places inside the chassis. |
30th Jul 2015 2:52pm |
