Home > Technical > Series 3 : lost all forward gears . |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2166 |
All of a sudden , no warning . I have reverse no problem but cannot engage a forward gear , it just won't let me in . Something preventing stick from engaging . Also the overdrive gear stick seems more loose and wobbly .
All fluids are topped up and clutch is good .hmmmmm Any help please Keith |
25th Jul 2015 12:35pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
Sounds a bit like the main shaft splines have worn down. Probably not worn evenly and allowing enough bite for reverse to appear OK. I think you my need to pull the overdrive off and check the splines.
Edit - just found this link which says the same thing http://forum.landrovernet.com/archive/index.php/t-173398.html Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
25th Jul 2015 12:54pm |
Top man Bob .
Great link , I was thinking down that route .. OD box coming off . Keith |
25th Jul 2015 1:05pm |
