Home > Wheels & Tyres > Viability of mud terrain tyres - Braking and Balancing ? |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 570 |
I run Insa Turbo 285/70/16 on my challenge truck,& have driven plenty of miles on tarmac.
Getting them balanced can be a problem,most garages,a 35" tyre wont fit on the balancing machine,if you do find one that will you will have loads of lead weights stuck to the wheel.Or you could go with balancing beads. On road grip is not the best,OK in the dry,but on wet tarmac can be a bit scary. Then there is the noise.........Dont expect to be able to hold a conversation at anything above 30mph. They are the dogs danglies in mud though. Marc |
23rd Jul 2015 6:40am |
Balancing....
If you don't 'need' such an aggressive tread pattern don't bother, the noise will be horrendous. I use Dynabeads....mixed reviews but mainly because I think people didn't put enough in. Work for me, no weights with 8" rims and 305 tyres. http://www.defender2.net/forum/topic29747....=dynabeads If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
23rd Jul 2015 7:03am |
Nostromo Member Since: 17 Jul 2015 Location: The Mendip Hills Posts: 73 |
Thanks for the above replies,
I've always been very sceptical about DynaBeads but thought I'd have a look on line and see if I could find any convincing evidence, one way or the other, to support the notion that they can really balance tyres ? Have to say, most stuff I've read was people arguing that there's no explainable science behind them and thus they probably don't work . . . that said, I found this YouTube clip which is exceedingly interesting to watch and appears to demonstrate that they might actually work . . . well maybe ! ! . . . link below:- I'd be interested to know what you good people make of this little bead demo ? . . For me, if these beads do work, then they'd completely resolve all my concerns and hesitations about investing in a set of mud tyres. That said thanks for the associated comments above re road noise . . . but, I think I could live with that as it would only be an issue getting to/from the places where I would be wanting the advantage of the Mud Tyre grip. Anyway, do let me know what you think of the Youtube clip ? ? ? . . . Cheers |
24th Jul 2015 9:04am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16884 |
I've run BFG muds, both the originals and KM2s, for getting on for 400,000 miles altogether on my Disco2 and Defender, with no stability, braking, or steering issues whatsoever. I can honestly say that they are better on the road than some road tyres I have expetienced.
They can become noisey as they wear, they need careful and regular rotation to even out directional wear patterns, and they can be difficult to balance. The KM2 tends to be more difficult in these respects than the original, and is more prone to picking up stones. |
24th Jul 2015 9:17am |
