Home > Technical > fuses |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6265 |
So I definitely had the ultra gauge go blank for a moment the other day and suspect I've seen go blank several times previously?
I reckon the battery is fine but several times the ultra gauge has had an alarm on start up to say low battery? Last night I had a good fiddle with work under the drivers seat taking fuses out cleaning etc making sure everything was pushed home etc.... Anyhow tonight after four journeys today I started up and not only was the ultra gauge blank for a moment but then it did a search / detecting gauges.......dont ever recall it doing that other than for the first install...Any thoughts? |
9th Jun 2015 8:15pm |
9th Jun 2015 8:28pm |
P'd off to.say the f-in least. The battery terminal is well loose ......How didn't I notice this because
9th Jun 2015 8:45pm |
