Home > Technical > TD5 Earth point. |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
The cable that runs over the bell housing on a Td5 is usually the live cable to the solenoid on the starter James
1st Jun 2015 7:34pm |
Normally the main earth from battery comes from battery to chassis then on to transfer box in one cable lenght
unless someone has added a extra earth , take it you have checked what terminal it goes to in the battery box ? |
1st Jun 2015 7:47pm |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 326 |
Thanks guys but I have the starter fully connected. This is not a cable from the main loom but a massive black earth coming from the battery box. It doesn't fit the bellhousing bolts (ring too small) so I attached it to the chassis. The normal transfer box earths are present and the earth strap from the ECU to the chassis is also there. I am concerned that it must have been attached to one part of the engine as I obviously unbolted it. Its annoying because I photographed and labelled everything else and haven't had many other issues.
1st Jun 2015 9:56pm |
Ok im an idiot, battery live connected to earth point on chassis and earth connected to starter motor All sorted now
3rd Jun 2015 9:16pm |
