Home > Wheels & Tyres > Load index?
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Load index?
Does the load index matter hugely?
I've been looking at some Cooper AT3's - the load index on one is 116, the other is 120/123 - there is a price difference of around £35 per tyre, is it worth paying the extra?
I thought I was pretty jenned up on tyres but the load index confuses me Embarassed
Post #425791 23rd May 2015 9:29pm
Lambley
Anyone ??
Post #425988 24th May 2015 10:04pm
munch90
Google tyre load index to get the charts showing what the numbers mean in kgs
Post #425989 24th May 2015 10:06pm
martinfiattech
Do it the easy way. look at your chassis plate (VIN) there will be your.
Chassis number.
Max vehicle gross weight in kg`s
Max drive train weight in kg`s
1- This means 1 St axle gross weight.
2- This means 2 nd axle gross weight.
As long as your tyre max weights, when added together are over the axle weight your in.
So if your 2nd axle weight is 1200kg and both your rear tyres are 650 kg`s each +1300 kg`s Easy innit.
But don`t go and wack 350 kg tyres on one side and 1150 kg tyres on the other. It would be silly. I`ve seen it done.
Also make sure your speed ratings are N = 87 mph or above. You never know that hill may be long and steep !! Excuse the spelling I`am better with spanners and wires.
Post #425996 24th May 2015 10:23pm
Lambley
Thanks martinfiattech,
My 90 is 1200Kg front axle and 1500Kg rear, so 600kg and 750kg per wheel respectively.
So, 116 on the tyre chart is 1250Kg - that is more than enough?
Post #426031 25th May 2015 6:23am
munch90
when the dual purpose vehicle class ends for mot , then some 110/130 will become class 7 mot tests then the tyre rating will be checked for mot
don't know exact details / dates etc , not looked into it propely yet !!!
Post #426042 25th May 2015 8:05am
martinfiattech
Afternoon lads.
Yes your tyre weights are right. But I would always try and err on the side of caution with tyres.
By this I mean put slightly higher weight ratio tyres on than the max axle weight, along with matching weight rating, make / tread pattern. Etc. We have all over loaded a vehicle from time to time, I know I have.
I understand some times this is a financial issue. But safety is important. (he now thinks and wonders what is fitted to his own 90. At least I know my axle weights now !!) Off to have a look soon.
Munch, when does this end dual purpose class come in, this is the first I`ve heard of this. (I always thought it was some kind of tax dodge anyway)
Myself I`am class 4 and 7 registered tester. (would`ent want to get involved with class five, not worth the hassel) You would have think it would have been in matters of testing. Or at least in a special notice.
Still it will save some confusion. Just think what the motor home owners will make of it. I can hear the letters going to the caravan club already...... Excuse the spelling I`am better with spanners and wires.
Post #426120 25th May 2015 2:25pm
munch90
in special notices quite a while ago (2013 I think ) , don't know if there are set dates yet or if its even been sorted at all , but sure it is happening
google "dual purpose vehicle mot to class 7"
Post #426121 25th May 2015 2:33pm
martinfiattech
Ah yes, I remember now. Now, I`ve googled it !!
I spent more time reading the bit about the sprinter bottom arm ball joints issue.
Many a thorny subject within our workshop.
I think I printed it out and stuck it to some ones tool box, due to his ball joint addiction. That quarter he got stars against his test failures.
Still nice to see vosa moving fast on this one. Won`t expect anything till COPM 2 is sorted.
Thanks martin. Excuse the spelling I`am better with spanners and wires.
Post #426136 25th May 2015 3:38pm
Numnuts
United Kingdom 2005 Defender 90 2.5 TD XS CSW Santorini Black
Evening Chaps,
I'm still learning so bare with....currently running BFG 265/75/R16 123/120 S KO and managed to pick up a screw that tyre shop said just outside tolerance for repair. Typical, as tyre is like new. Big Cry
Anyhow, can't find an exact replacement, but finding 2nd hand tyres with same spec,but different load rating like 120/116 S.
Aesthetically looks spot on, but will I notice any difference or is it a no no?
Regards
Matt
Post #611232 21st Mar 2017 10:01pm
