Home > Maintenance & Modifications > TD5 engine oil drain plug? |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 |
Is this the drain plug of the 2003 TD5 engine?
I know this might be a stupid question, but I don't want end up with the wrong plug! I don't have the whole picture, there is a under tray cover up! Thanks everyone! |
20th May 2015 4:39pm |
Do you know how to use Google images?
Google can be your friend and get a quicker answer. First post.... http://www.landyzone.co.uk/lz/f50/sump-issue-108392.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th May 2015 4:55pm |
I did Google for it, still not sure if this is the one, I saw that post too!
Most of the photos and video are not TD5... |
20th May 2015 5:05pm |
JJ440 Member Since: 08 Nov 2013 Location: Geneva Posts: 51 |
Picture is to close for me but the proximity of the exhaust seems to indicate it is. Don't know what that gunk is though, hope you won't have problems tightening it back up.
Found this on google, first hit for td5 oil change: http://www.discovery2.co.uk/oil_change.html |
21st May 2015 8:32am |
Many Thanks, I also keep that link in bookmark!
21st May 2015 12:18pm |
