Home > Td5 > Td5 engine/ driving question |
Had exactly the same thing and thought the engine mounts were on there way out. Does your engine make a chirp sound when you switch off too? Mine was the crankshaft pulley (or harmonic damper) on its way out, if you do a search on here for crankshaft pully or read this good description and fix if the symptoms sound familiar.
http://www.discovery2.co.uk/CrankPulley.html Ray My build thread http://www.defender2.net/forum/topic17615.html |
11th May 2015 12:06am |
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 |
4th Oct 2017 7:51pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
Is it the emisions control? Mine dos it if I coast up to lights. I've read others have had similar problems 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
4th Oct 2017 8:21pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2223 |
Mine makes a chirp sound when l turn off the engine but it's just the aux drive belt, a bit of WD 40 silences the chirp for a short time.
The belt has been replaced which de-chirped it for a while but the chirp has returned. l checked the tensioner which seems fine. |
5th Oct 2017 8:27am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2063 |
Can be high idle and low idle. Some do it more than others.
5th Oct 2017 8:29am |
