Home > Maintenance & Modifications > Spring Spacer Questions.. |
If you mean things like these:
Click image to enlarge You can see them fitted here: Click image to enlarge Pro's: Cheap easy You can use the same front shocks. Rear you should or use longer shocks or use lowering brackets. Longer springs: Should give you more travel but need 4 new longer shocks If you do this to fit taller tyres you need in both cases longer bumpstops. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
7th May 2015 9:19pm |
