Wheel Carrier Spacer?
Hi ALl,
Not sure if this topic has been covered. I'm just about to fit some 285s and I've heard that unless your wheel has a decent offset, the rear wiper will need to be removed to fit the spare on the back door. Does anyone know how to solve this or if there is a spacer kit I can get? Thanks.
14th Apr 2015 4:57pm
dozerman
I put 285s on boosts and they fouled my wiper. Swing away carrier sorted it out though!
14th Apr 2015 6:42pm
K9F
From an old thread......
K9F wrote:
Offset can often be adjusted by the adjustment spacer fitted to the original carrier studs to move it away from your wiper arm if required.
If you go through life with your head in the sand....all people will see is an ar5e!!
