Home > Technical > Starter
Sidcoupe
Scotland 2008 Defender 90 Puma 2.4 HT Cairns Blue
Starter
Can anyone tell me the easiest way to remove the starter 2.4puma thanks
Post #415672 12th Apr 2015 1:26pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
I've done it, there isn't an easiest way.
Disconnect battery.
Undo the two cables.
Remove top bolt from above and bottom bolt from below.
Fiddle motor out from below.
Sounds easy, takes ages and skins your knuckles.
If you think it's playing up, just try disconnecting battery, removing cables and cleaning up connections. That's what was wrong with mine having taken it off for bench testing.
When you re-connect, as you tighten the big cable it's possible for it to twist round and short against the little cable. Take care to avoid that.
Post #415711 12th Apr 2015 4:28pm
