Home > Maintenance & Modifications > Urban Truck DRL |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Lets see some picks then.
It's the white wire on the ignition |
8th Apr 2015 7:33pm |
CLCraig Member Since: 05 Aug 2014 Location: Somerset Posts: 104 |
Going to be my weekend project so pictures to follow then. Had a look this evening at the wiring so I have a rough idea.
8th Apr 2015 8:48pm |
If you use a drl controller you dont need a ign live
how does it say to wire them ? |
8th Apr 2015 9:08pm |
Click image to enlarge |
8th Apr 2015 9:36pm |
Ok the drl controller they using is just a dimmer for when sidelights on , not voltage sensitive controller
there are lots of different controllers you can get and some use ign live and some just permanent live and earth Does it dim drl,s when sidelights on to turn off drl,s when sidelights on ? |
8th Apr 2015 9:44pm |
It dims the DRL's as far as I'm aware. Which is what I would like.
8th Apr 2015 9:57pm |
yes i think the dimming are better looking
8th Apr 2015 10:01pm |
i still think you need to connect to the white wire. Mine dim on side lights.
8th Apr 2015 10:03pm |
Davie L Member Since: 04 Sep 2014 Location: Glasgow Posts: 95 |
Hello
Ive just fitted the Quad DRL bumper from Urban Truck, Ive taken the feed straight off the battery through inline fuse to the controllers. There is some wires on the controller that you don't need I think it's a .5 brown and .5 red if I remember right these can be cut off. Connect the whites to the posi on the side light and this will enable the DRL'S to dim once the sides are on. Pic of mine in my album, Don't know how to upload it here though. Davie |
8th Apr 2015 10:10pm |
If its non voltage sensing then you need a ign live
The reason i asked as some just use perm live and switch on automatic when engine starts by sensing charge voltage this way they stay on for 30 secs or so after you switch off as a kind of see you home function |
The white is ignition live.
8th Apr 2015 10:13pm |
Whites go to the sides for the dimming function 👍
8th Apr 2015 10:15pm |
^^^ think he means the white wire on defender is ign live
yes white of drl wiring to sidelight |
8th Apr 2015 10:17pm |
8th Apr 2015 10:28pm |
