Home > Wheels & Tyres > COOPER ST Maxx 265/75x16 WHEEL COVER
Litch
Does anyone have 265/75x16 Cooper ST Maxx tyres and successfully fitted a spare wheel cover? If so, where did you buy it from please?
My old 265/75x16 were BFG AT and the old semi-rigid cover does not fitted the Cooper's as they are a larger diameter plus wider despite being the same tyre size. The Coopers are 31.5 Inches x 10.5 inches while the BFG's are 30.5 inches x 9.5 inches, even when brand-new I don't think the BFG's were more than 31 inches.
Some cover suppliers state that they don't have a semi-rigid cover that will fit while others just say that all 265/75x16 tyres are exactly the same size so therefore their cover will fit (I know this to be wrong so am not going there).
I want to cover the new wheel / tyre but at the moment am thinking I might have to buy a universal loose cover.
Help. Crying or Very sad ONE LIFE, GET IT!
Post #412333 30th Mar 2015 2:20pm
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
I have an LR semi-rigid cover on a wheel/tyre combination (275x65x18") with a diameter of 815mm (32.1'') which is therefore 9mm (1.1%) taller than the 235x85x16" standard size of 806mm (31.7''). Now admittedly it is only 'just' on but given that your overall diameter is smaller than this you should be able to fit yours. The trick is to hold the flat rigid part flat against the wheel with the wrap around part inside out and then progressively fold this over the wheel. I hope I'm not guilty of trying to teach my grandmother how to suck eggs but it might be worth a try.
Post #412599 31st Mar 2015 9:10am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
try Paddock spares they have semi rigid with or without paddock logo. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #412600 31st Mar 2015 9:13am
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Litch
I have a cover that fitted a 31 x 10.5 x 15 tyre on my S 2a
Free if you pick up from me since I see you are in Beds.
Pm if interested 1970 Series 2A 88"
Post #412616 31st Mar 2015 10:12am
Litch
Thanks for the replies.
My issue is that I already have a semi-rigid cover that I have used on my old 265/75x16 and it doesn't fit the new tyres. Various suppliers have said that yes, their cover will fit as all 265/75x16 tyres are the same size (they're not) or no, their cover won't fit my tyres (which according to them are oversized). I have even spoken to a manufacturer who states that their largest one (which is a standard LR item sold by many outlets) will not fit.
I had a similar problem when I first bought a set of BFG AT's in 265/75x16 over 15-years ago. Normal semi-ridged covers didn't appear to fit but then one specialist asked what make of tyre I had, I replied that they were BFG and he said that they produced a special cover for that tyre as it was slightly larger than normal. I tried it there & then and it fitted perfectly (it even had a sticker in it stating that it was for BFG only). Unfortunately this specialist (which was local to me) is no-longer around.
It was really to see if anyone had a plain semi-rigid cover that fitted this particular tyre and if so, where did it come from? ONE LIFE, GET IT!
Post #412799 31st Mar 2015 8:57pm
