Home > Maintenance & Modifications > Can you use later vent handles on 2000my TD5 |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
Can you put the vent handle from a late td5 ie the one which have a threaded knob on the end on a earlier TD5 with the vent handles with the moulded plastic end?
28th Mar 2015 1:20am |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Not without changing quite a lot of stuff, the inner frame of the dash that they hinge and latch on is different as is the dash fascia itself.
I had the same idea myself with one of my previous Defenders, a 2001, when I fitted a later style dash to it, I eventually gave up on the levers and cut the dash slots a little wider to make the old ones fit the new dash. |
28th Mar 2015 11:24am |
