Home > Technical > Rear door opening while driving |
Have you adjusted/checked the striker plate and checked the rear hinges for security of attachment/worn pins. If you sit in the rear with a torch and the door shut you should be able to see what's going on with the striker plate.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
16th Mar 2015 8:16am |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 941 |
Thankyou, the striker plate wasn't aligned properly. That was an easy job I managed to complete on my break in the college car park
17th Mar 2015 2:14pm |
Good result! If you go through life with your head in the sand....all people will see is an ar5e!!
17th Mar 2015 3:08pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
Good work Mal...
And pdq too... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
17th Mar 2015 3:23pm |
GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555 |
I had this on mine when on the sliproad of the M6 travelling to Peterbrough last year Rear door flew open and stuff everyhwere An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
17th Mar 2015 9:22pm |
