Home > Technical > A Squeak and a Clank! |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 |
My self I would jack up the back end. Check for play in any suspension joints, prop uj`s and wheel bearings. ( make sure any and all bearings are running true and not over heated).
Drop the wheels off check the brakes are ok, not seized etc. Excuse the spelling I`am better with spanners and wires. |
15th Mar 2015 11:19pm |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
Face it dude you are just getting old.....
The squeaky groan Is an involuntary utterance,. You may find self also going "ooooooffffffffffffffffff" when standing up or sitting down. If it only happens when you are warm take your coat off before you set off. The clank is the sound of the unsecured Zimmer frame rearranging itself in the back of your truck. A good Overland equipper should be able to sort you out with a cunning arrangement to keep is in one place. Don't worry about either......but be very, very concerned if you find yourself ordering "comfy trousers" with an elasticated waist band from an advert in the Sunday colour supplement (actually just be concerned if you are reading the Sunday colour supplement!) A pleasure to help as ever . |
16th Mar 2015 9:14pm |
Northernremedy Member Since: 18 Aug 2014 Location: Yorkshire Posts: 122 |
Hahaha. youve hit the nail on the head! I forgot about my knees
Cheers I will whip the wheels off and get my hammer out. |
16th Mar 2015 9:16pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
I thought it was twist and shout?
On a side note, have a check of your A frame joint and radius arms Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
16th Mar 2015 9:26pm |
Maybe a grunt and a wheez!!
Cheers will check that |
16th Mar 2015 9:31pm |
OOhhhh.
At what age does this creak start to happen. I`ve just started to make a happy kind of groan when I sit down of an evening. I`am a little worried. Excuse the spelling I`am better with spanners and wires. |
17th Mar 2015 10:30am |
NickH Member Since: 02 Nov 2014 Location: Halifax Posts: 204 |
As soon as I went 40 last year the noises started,
Whenever I bend down or stand up an involuntary "aahhh" or "ooofff" comes out of my mouth. Must be gettin old, need to get a twenty something dolly bird to keep me young 2003 Td5 90 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
17th Mar 2015 3:43pm |
