Home > Maintenance & Modifications > ARB Compressor Mounting |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2642 |
Where ever you mount it ensure it is on rubber mounts. It will vibrate and cause lots of vibrations when it's running. 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
10th Mar 2015 11:13am |
LandyBen82 Member Since: 22 Jul 2014 Location: Shropshire Posts: 44 |
I have got loads of thick rubber washers at work, they might work??
10th Mar 2015 11:19am |
Trial and error I think. Try and position it near some bracing. ie if you mount in on a flat panel then try and do it where the bracing runs on the otherside. Or mount in a corner where the panels have less scope for vibrating.
Ensure you use the backing plate that comes with the compressor. That will help a lot as well 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
10th Mar 2015 12:26pm |
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 |
Not sure which model 90 you have or what size compressor you have but in my 90 HT with no rear bulkhead I have mine mounted on behind the driver's seat, on the top of the rubber matted wheel box.
I have quite a lot of non-standard gubbins in there - fuse box, roll cage and load barrier (dog guard) but it fits fine. Done 15k miles around Australia on a lot of rough tracks and not had any problems with it, and no vibrations to speak of. Usually the air line is coiled a bit tidier than in the picture and tucks away down the side of the roll cage. Been a bit lazy with my tidying up of late! Still loads of "Red Centre" sand in there! Click image to enlarge Our blog - http://landytravels.com/ Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
10th Mar 2015 12:57pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2086 |
Mine is behind the passenger seat next to the rear bulkhead.
Mo The Land Rover 90 - Many are called, few are chosen. |
10th Mar 2015 4:03pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
Mine is mounted between the passenger seat and the bulkhead, mounted on the bulkhead. Been there 5 years, no vibration and accessible for tyre inflation. 2007 TD5 90 Hard Top
11th Mar 2015 12:01am |
So is it a big job to get under the passenger seat. I will wait for it to arrive and have a good scratch of the head.
Thanks - Ben |
11th Mar 2015 9:49am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2266 |
Mine is located under the front left wing (LHD). It has been there for years and no trouble at all. Puma 110" SW
11th Mar 2015 10:19am |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
Mines behind the driver headlight with the airline running to the gmb wingtop storage locker 2004 TD5 Defender 90 xs station wagon
11th Mar 2015 11:19am |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2163 |
Click image to enlarge |
11th Mar 2015 2:17pm |
