Home > Technical > Engine oil ?
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Engine oil ?
Hi guys
Is it safe to mix castrol magnatec 10w40 diesel oil B3 with castrol magnatec 10w40 diesel oil B4 Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #405471 7th Mar 2015 11:36pm
MK
A3/B3 Stable, stay-in-grade oil intended for use in high performance gasoline engines and car & light van diesel engines and/or for extended drain intervals where specified by the engine manufacturer, and/or for year-round use of low viscosity oils, and/or for severe operating conditions as defined by the engine manufacturer.
A3/B4 Stable, stay-in-grade oil intended for use in high performance gasoline and direct injection diesel engines, but also suitable for applications described under A3/B3. Puma 110" SW
Post #405592 8th Mar 2015 1:53pm
Retroanaconda
Oil is oil, it'll be fine.
Post #405593 8th Mar 2015 1:54pm
Naks
worst advice ever #smh
Shocked --
Post #405646 8th Mar 2015 4:20pm
Retroanaconda
Hardly, the OP is talking about a 200Tdi - these are not exactly fussy when it comes to oil. Furthermore he listed two oils of the same grade from the same manufacturer, so they're perfectly compatible. Even mixing grades is fine, you'd just end up with something in between.
Any Tdi is going to be happy with just about any 10W40 or 15W40 whether synthetic, semi, or mineral, and will have no issues with combinations of any of them. Mine gets whatever I can lay my hands on at the time, currently I have found a good source of 10W40 semi-synthetic at the local agricultural suppliers place so it's getting that. Gets changed every 6,000 miles anyway so hardly worth chucking expensive stuff in.
For more modern engines there may be more stringent requirements, but if it's the right grade and meets the spec then chuck it in - it will all mix without any problems.
Post #405650 8th Mar 2015 4:37pm
Naks
fair enough.
I always assume people are talking about Pums since this is Defender2.net Whistle --
Post #405653 8th Mar 2015 4:49pm
cornish rattler
Cheers for that i will get on with it at the weekend Thumbs Up Graham
Post #405843 9th Mar 2015 1:12am
