Home > Maintenance & Modifications > Head light upgrade wiring problem |
Derrickthedefender Member Since: 28 Jan 2014 Location: South Posts: 294 |
It's the two connectors at the bottom of the top picture that I don't know how to connect...
These are the wires I have in at the moment, I know the two for the headlight, and the connectors for the indicator and side light, but what is the other one for? Click image to enlarge Click image to enlarge A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!! Yes the name for my 90 is Derrick! |
4th Mar 2015 4:43pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
headlamp levelling
4th Mar 2015 10:45pm |
So where does that connect to? A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
5th Mar 2015 9:39am |
The headlamp leveller if one was fitted which will be a small motor on the headlamp bucket. But not all defenders had them
5th Mar 2015 10:24am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
For the side light I think it is referring to the little red wire on the headlight bowl?
The effect being that when you click sidelights only it will illuminate your headlight bowl with a tiny bulb rather than just your marker lights. You would need to run a cable from the small red wire to the red wire of the sidelight fitting but if this is not the desired effect I wouldn't bother as your headlights will it will work fine without it. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
5th Mar 2015 11:09am |
Thanks Shaggydog, done just that and works perfectly A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
6th Mar 2015 9:33am |
