Home > Technical > Dipped headlights with full beam...is this right?? |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 666 |
You don't have a problem, this is how the headlights are wired....
27th Feb 2015 11:35am |
Mazzaman32 Member Since: 24 Apr 2014 Location: Kent Posts: 20 |
so I'll need to drive along with the stalk pulled back to get more light
I guess upgrading to LEDs etc is the option of improved light at night! thanks for clarifying |
27th Feb 2015 11:45am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5422 |
As above all is normal. But it is a shame that you loose light with the way they are. But if wired so both elements were permanently on they would fail due to the heat.
Crystal clear lights, and osram night breaker bulbs are plenty good enough for me. I think other people struggle with the headlight brightness due to driving other inferior vehicles with posh headlights, simply solved by being more faithfull. Andy |
27th Feb 2015 11:57am |
