Home > Technical > TD5 Crank Pressure |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Also to note, the PCV is new. I have no rising oil level to signify injector seals. Just seals popping and my general concern. Just worried if the pressure is in the sump to, I might start popping crank seals.
Also to add, it's had a recent, VNT, IC and strong Map. |
21st Feb 2015 3:32pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10360 |
No luck?
22nd Feb 2015 11:26pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
You can measure crankcase pressure but don't blank the hole off, maybe make a 'T' directly after the cam cover exit this should give you an indication of maximum pressure whilst under driving conditions. Maximum load should do it.
Blowby should be measured as a flow rate to determine engine condition, eg; Litres/min plenty of info. on the web how to measure this. Could your catch can have introduced a restriction creating higher than normal pressures in the engine? Diesel engines do have higher blowby than petrol and undoubtedly this has increased with the extra tuning you have done. |
25th Feb 2015 2:00pm |
Fully understand about not blocking it. That would result in major works! I have a couple of various 'T' sections I've used for testing various things so should be able to make something up.
The catch can isn't causing any issues as the same pressure is there with the catch can off and just the cover flowing straight out to atmosphere. Out of the catch can, it goes to the normal (new) PCV, and the pressure coming through the PCV is the same/similar as before the can (and Turbo as they went on together). Also fully understand that diesels are heavy breathers (this is just more than expected, though I haven't 'felt' another TD5 to gauge the difference). With regards to the tuning, I dont think that would have caused any extra pressure whilst sitting at idle. Could possibly understand it at load however, but not a major difference. |
25th Feb 2015 2:52pm |
