![]() | Home > Technical > Horn problems |
| stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1034
Hi all,
Has anyone had the issue that I have? When using the rear wash wipe the horn sounds! The horn works normally on the stalk but the rear wash fails to operate! Had a quick word at the main dealers last week when I took my wife's freelancer 2 in and they hadn't heard or experienced anything like it Thoughts and ides appreciated Greg Forgot to add 2011 Tdci usw |
I've had it from new and not touched the wiring , it's only just happened in the last month!
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Then that's odd. Has it been in for any work at all?
Nope nowt,
In that case someone more electrically minded should be along soon
Ray |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327
That is really bizarre, you'd think it was an earth fault but I even think that the horn and rear wash wipe are in different fuse boxes.
The only other thing is that maybe there is a shorted wire somewhere, especially if the location as described above putting the looms for the rear wash and horn in the same place. Check for a mouse nest! What happens if you pull the Horn fuse out? On your model, I think it's Fuse 3 in the fuse box under the drivers seat. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Well finally got to the bottom of it! Chaffed wiring behind headlight , two wires chaffing on each other , sorted under extended warranty
