Home > Maintenance & Modifications > Gas rams |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1757 |
Hi Andy
I have used these guys before for rams for a boardroom AV unit and university computer desks, their technical dept are really good helping you choose the correct Rams for your job http://www.sgs-engineering.com/gas-struts Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 250D XS |
31st Jan 2015 9:51pm |
There are plenty of companies that sell the struts and many offer a tailer made service where they can provide them to your specs, quick google brought up the likes of this company........ http://www.sgs-engineering.com/gas-struts
I'm too slow in typing Last edited by JWL on 31st Jan 2015 9:53pm. Edited 1 time in total |
31st Jan 2015 9:53pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16892 |
I always use this place and have had excellent service from them.
http://www.strutsdirect.co.uk |
great minds eh 2014 110 2.2TDCi XS Station wagon
31st Jan 2015 9:55pm |
NickH Member Since: 02 Nov 2014 Location: Halifax Posts: 204 |
Hi Mate
try SGS engineering, they do them. I would mark a point on your cage and a point on your lift up bit about 300mm apart and hold some string on each point while someone opens it, this will give you 300mm closed length and the length you need when its open. Obviously there will be some messing about with dimensions and positions of your marks but you will be able to work out the length. Second thing is weight , on the frame that opens , I would clamp a spring balance to where you think the strut will mount and see what force is needed to lift it. Dead easy.....not Thats how I have done it in the past 2003 Td5 90 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
31st Jan 2015 10:03pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5424 |
Great thanks. Have not yet looked at links, but are they costly? Are there any rules thoughts on how to mount them? One part higher than other, always do X etc. or do you get rams and design around the rams?
Andy |
31st Jan 2015 10:04pm |
Hi Andy
We specified the ends, fixings, length stroke etc in conjunction with SGS technical guys, you just need to provide them with some information on sizes, weight if opening vertically, type of use etc. If I remember correctly the total cost for the fixing plates ends and Rams came in around £70+VAT. Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 250D XS |
31st Jan 2015 10:17pm |
