Home > Technical > Rear Lights not working |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 |
Check the earths, also check for frayed wires as something has caused the fuses to blow.
There are a couple of threads about this. |
11th Jan 2015 10:10am |
Tom DCab Member Since: 13 Jun 2013 Location: West Sussex Posts: 33 |
Hi, thanks for replying.
I just fitted the old numberplate light back again and all ok now. The old numberplate body has a metal base plate that attached to the plinth. The bolts go through the metal and secure to the bodywork. I am not an electrician but I am guessing this metal on metal contact through the light fitting is necessary to make the lights work properly. The Led numberplate light does not have a metal base plate, so I am not sure how it is ever going to work... Tom |
11th Jan 2015 11:00am |
It seems that your rear lights are earthing through the numberplate light plinth which is not how it should be. The earth circuit should be via the black wire to a separate earth connection (on the transfer box).
Check the earth connection on the transfer box that is referred to in this post. Earlier land rovers had the earth as a separate connection to the body panel behind the lights. |
11th Jan 2015 2:11pm |
Could try disconnecting tow electrics as they can short things out if they aren't well looked after
11th Jan 2015 4:26pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19608 |
Yes, the towing electrics can cause all sorts of oddities to occur.
11th Jan 2015 4:55pm |
