Home > Maintenance & Modifications > Wheel Spacers
Anderzander
Wheel Spacers
Can any point me towards any wheel spacers that are less than the normal 30mm ?
I don't want too much width - just a bit more lock and thought I'd seen some at 25mm ...
Post #383809 1st Jan 2015 8:51am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I think the minimal thickness depends on your wheelstuds as you will tighten the spaces with your original studs and your wheel will be thightened on the studs build in the spacers.
I don't know the length off the studs but they will be close to 3 cm. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #383810 1st Jan 2015 9:42am
Anderzander
Thanks for the reply Roel
There is a bit of room though .... Here's a picture of some 30mm fitted to my friends truck - you can see you could take some width out ......
I have seen some 25mm ones for sale in the past - just not finding them now. There are thinner ones - but not hub centric, which I want.
Post #383818 1st Jan 2015 10:16am
