Home > Maintenance & Modifications > -14 to -20 have you topped up your antifreeze?
gilarion
With temperatures predicted to drop to between -14 to -20 degrees in January (if the MET office is right!) have you topped up your antifreeze?
According to both the AA and RAC antifreeze service is one of the most forgotten things in home car maintenance ‘Because modern antifreeze can last up to five years people forget to check its condition, we recommend that all types of antifreeze is checked before each winter period and ideally the antifreeze is replaced with a complete engine flush every two years’
A gallon of antifreeze is a lot cheaper than a new radiator or having your core plugs attended to.
Post #381978 26th Dec 2014 1:16pm
CatherineF
Our car had a 48K Mile Main Dealer service last spring, would new antifreeze have been put in it?
I notice it had an engine flush according to the invoice.
Post #381982 26th Dec 2014 1:29pm
K9F
Doctored an answer for you...... Thumbs Up Rolling with laughter
CatherineF wrote:
Working in the Motor Trade I'd put money on the fact............that they probably wouldn't have given a second thought to adding antifreeze when the job was done. I will check though and carry out a 'belt and braces' approach by adding antifreeze myself. For the sake of a little time and next to no money this could potentially save me a bucket load of grief.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #381985 26th Dec 2014 1:37pm
CatherineF
LOL!
Someone reads my posts at Christmas - YAY!
Post #381988 26th Dec 2014 1:44pm
Andrew james
United Kingdom 2015 Defender 110 Puma 2.2 USW Indus Silver
I am about to go to in Norway, so I am good for minus 50 Very Happy .
Bring it on!
Post #381991 26th Dec 2014 2:08pm
shaggydog
Thanks for the reminder- I always check level but rarely consistency!
Should be ok but needs a top up so will top up with coolant Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381994 26th Dec 2014 2:12pm
jimbob7
This Pov.spec,ftw. 2006, 110,TD5.
Post #382011 26th Dec 2014 3:32pm
Fatboy Slim
Wales
Just buy a cheapy tester and check it. Too much is just as bad as not enough Thumbs Up
Post #382042 26th Dec 2014 5:03pm
jimbob7
Don't think the usual testers can test oat anti-freeze,dunno?? Pov.spec,ftw. 2006, 110,TD5.
Post #382043 26th Dec 2014 5:08pm
Lou Sparts
What problems does too much anti freeze cause ? Checked mine and Mrs Sparts the other day hers was ok to about -32 mine was about -40 !!! 2005 Td5 90 XS
Steve
Post #382047 26th Dec 2014 5:11pm
Fatboy Slim
Wales
Yep they do
Post #382048 26th Dec 2014 5:12pm
Fatboy Slim
Wales
Too much anti-freeze actually freezes and can cause overheating problems believe it or not. Your specs are fine
Post #382049 26th Dec 2014 5:13pm
SGH
Run Evans Waterless Coolant in my vehicles good to -40.
Post #382057 26th Dec 2014 5:39pm
55% mix good for -50C Thumbs Up
Post #382077 26th Dec 2014 6:22pm
CatherineF
Had the bonnet up on her today and there is a Land Rover Label about genuine Land Rover Anti Freeze and Do Not Drain.
Is this something that would have been on it from the factory or does it sound like it's been applied at a service?
Post #382330 27th Dec 2014 4:05pm
