Home > Maintenance & Modifications > Anyone in Hants or Surrey handy with a welder....small job |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Chaps ive a small leak at the top end of my rear diff casing.im based in Aldershot ..can travel with the truck after someone whom might be able to pop a spot of welding over the hole for me..currently in Peterborough but back on Monday ...
13th Dec 2014 7:20pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
To be honest, the diff casing is so thin you run the risk of actually making it worse! [Unless you are a pro welder]
You'd be better off cleaning/degreasing the area and repairing it with a compound. JB Weld is great for that sort of thing Guns and Landrovers .... anything else is irrelevant. |
13th Dec 2014 10:05pm |
dave thanks very much for the advice.
Terry |
13th Dec 2014 10:12pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
If you're passing south wales at all I'm sure I could help you out. I work for hobnobs
13th Dec 2014 10:25pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1756 |
You could use something like this I did a temporary repair on a sump with it and it was still there 4 years later when I changed my car.
http://www.amazon.co.uk/J-B-Steel-Reinforc...B000786GLM 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 250D XS |
13th Dec 2014 10:42pm |
Cheers guys thank you all for your help ,input
Terry |
13th Dec 2014 11:51pm |
