Home > Off Topic > Key fob interference |
Obviously as your problem appears to be geographical you need to consider local conditions perhaps?
Radio/television transmitter, mobile phone mast, electrical pylons, local radio ham operator basically anything local to your house that may interfere with the fob emmision. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
30th Nov 2014 10:43am |
I noticed my defender fob at home didn't work a couple of times when walking over to it , then noticed the electric gate opening and it was the wife opening gate with her gate fob killed signal from defender fob otherwise it works fine also it does did to discovery fobs as well , customer had discovery that wouldn't unlock when he was out on a shoot moved discovery and it worked fine , showed him what can happen by doing gate fob while he tried his fob and it done same thing
30th Nov 2014 11:01am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
Most fobs are 433MHz which is quite a well used band. Usual culprits for interference on the band are cheap wireless doorbells (obviously intermittant) weather stations (intermittant), thermostats or most likely a (cheap) wireless cctv system
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
30th Nov 2014 11:12am |
