Home > Puma (Tdci) > Yet more Trouble (Gear Box Related)
Forest of Dean 90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
LR fitted a New Gear Box 3 Weeks ago because of Notchyness (under warranty which has now expired whilst the vehicle was still in the work shop), first time I select Diff Lock it wont come out of it the Selector stick keeps jumping over to the left (Diff Lock Position) you go to disengage by moving the Stick to the right and it just jumps back to the left position so the Diff Lock wont release.
The New Box is even more notchy than the Old Box, I'm at the end of my tether now !!! what can I do I like the Landy but I need a Vehicle that works Day in Day out.
Please help !!
I know this sounds like a moan, but what can I do, I have lost all faith in it. Big Cry
Post #32271 15th May 2010 8:46am
Grockle
take it back and show them,they will have to sort it for you,or call LR customer services first 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #32274 15th May 2010 9:09am
MK
probably you are in the situation where you need a good LR mechanic. Perhaps they did not set up well the diff lock lever. Now about the GBox, have them to check the clutch plate.
Also, check on the number plate of the Gbox. Puma 110" SW
Post #32277 15th May 2010 9:41am
110SEB
...as well as complain til you're blue in the face. Then make sure you ring LR Cust Services and complain until you get at least £1000 in "good will" compensation to spend at your dealership and a few free services. It's what they're there for Thumbs Up
Post #32279 15th May 2010 9:44am
fekete
Hi i had a simler problem with mine.....New box was worse than the old with selecting ...took it back and they had another go perfect Thumbs Up ...........Just take it back and get the head mechanic to sort it out NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #32280 15th May 2010 10:31am
