Home > Maintenance & Modifications > Need help with Bilstein Rear Shock Bushing Assembly
Mech
Hello All. Thanks in advance for any help you can provide.
I am putting new springs and shocks on my 1991 200tdi 110. I ordered a set of Bilstein B6 Yellows and std springs. I'm having a bit of a problem with the rear shocks though as I can't seem to figure out which washers go where. The kit only included 4 washers. The bilstein guide is written in hyroglyphics and is somewhat useless.
I would expect 6 washers. two for the top and four for the bottom. What am I missing here?
Thanks
Post #363465 9th Oct 2014 9:14pm
munch90
depends on what back axle you have as some have cup washers fitted ( actally fixed to the shocker mount on the axle ) to the axle and some don't , can't remember what years are what
but would think a 91 would not have the fixed cups
but looking at the picture again I would say all four are for the bottom and reuse the top ones ???? but the holes don't like right
now I'm confused as well
Post #363467 9th Oct 2014 9:18pm
Mech
Its a Salisbury Rear. The brackets don't include any kind of welded washer. Theres just the bracket with a hole in it.
None of the washers will fit over the thick part of the top shock mount. I'm beginning to think that maybe I was supposed to reuse my old top washers. They were pretty rough though. I dunno.
Post #363475 9th Oct 2014 9:32pm
munch90
yes would say you four for the bottom
top washer like the bottom one nearest the rubbers in pic
two like the top ones in pic but with smaller holes then the ones in the pic and a lip round hole to fit in hole in axle mount
bottom washer same as top washer but with smaller hole
top washer I mean top of the bottom mount
reuse top washers (chassis mount)
in the pic the two top washers look like they got a bigger hole then the rest , bit hard to tell
I think you should have three washers with same size hole and one with smaller hole
Post #363481 9th Oct 2014 9:40pm
jst
lettering washers A - D (A, B on top starting on Left etc)
i understand it would be
C
rubber bush
A or B
axle
B or A
rubber bush
D
reuse the existing top shock washer with larger rubber bushes. flange out! Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #363487 9th Oct 2014 9:45pm
Mech
Understood. Problem is my top washers are Censored . Suppose I'll poke around the vendor sites.
Post #363491 9th Oct 2014 9:51pm
silky16v
England 2001 Defender 90 Td5 X-Tech LE Blenheim Silver
Look on the shockers themselves they have numbers on them relating to the picture diagrams from bilstein showing how the washers should be mounted
Post #363510 9th Oct 2014 10:43pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
There are some pictures in this that may help...
http://www.defenderhelp.com/11-suspension.html
Post #363518 9th Oct 2014 11:13pm
Mech
Got it sorted. Thanks guys. I took my old top bushing washers, sandblasted them, powdercoated them and put em back on. I also ordered some stainless ones.
There still seems to be a lot of contradiction from reliable sources as to which way they go. I went with my best judgement and installed the top ones with the flat side away from the shock and the dished side towards the shock. For the bottom ones, I mounted them as per the bilstein guide.
Post #363633 10th Oct 2014 7:40pm
munch90
that's it dished side to rubber Thumbs Up
Post #363670 10th Oct 2014 10:04pm
