Home > Maintenance & Modifications > Laminated Door Glass
shaggydog
Hi Guys,
Just postulating here but has anyone ever fitted laminated glass to there doors?
Seems like a good way to put some added strength and security into a door.
I'm guessing would just need a sheet of 4mm laminated glass then cut to shape and bevel the sides.
Any reasons why not?
Has anyone ever heard of doing it or had a go?
Dog
Post #363019 7th Oct 2014 11:11pm
Clear film or a slight tint works Thumbs Up
Post #363025 8th Oct 2014 6:33am
munch90
if there was a accident and door wont open (on your roof etc ) it would be harder to get out
also would the glass put up with slamming the door ? don't know
Post #363026 8th Oct 2014 6:35am
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Laminated side windows are becoming more common in vehicles but retrofitting is not simply a matter of finding some laminated glass and having it cut to suit. Most laminated glass is 5mm or thicker so fitting it in the door window channels would be difficult if not impossible. Side glass also has different requirements to windscreens, it is not always supported all the way round the edge and may flex when the door is closed, which can crack standard laminated glass, this means that the glass although laminated still needs to be tempered.
More information here: http://www.pilkington.com/pilkington-infor...lights.htm
Post #363027 8th Oct 2014 6:50am
ClaireWright
United Kingdom 2008 Defender 90 Puma 2.4 HT Keswick Green
It's illegal to put laminated door glass in vehicles as it isn't strong enough for side glass,when it gets hot it's very weak and will crack easily.
Post #363035 8th Oct 2014 8:24am
shaggydog
I think that fairly conclusively puts that to bed.
Thanks guys and girls Thumbs Up
Post #363150 8th Oct 2014 7:15pm
smb
I would have thought Pilkingtons know what they are on about and that link tells of Laminated glass in doors becoming more common!
Post #363155 8th Oct 2014 7:33pm
