Home > Maintenance & Modifications > EGR Delete |
tuners only
5th Oct 2014 7:16pm |
CLCraig Member Since: 05 Aug 2014 Location: Somerset Posts: 104 |
Have you noticed whether it does the cleaning process when you turn off?
5th Oct 2014 7:37pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19578 |
Yeah it does mate.
Not always though which is how it's behaved since new, I think the new generation of EGR's don't do the cleaning cycle every time. The shutdown noise sound pretty much normal, no noises whilst running from it at all. |
5th Oct 2014 7:39pm |
I would guess the cleaning cycle would be ecu controlled not by egr itself
thinking about it , it must be ecu controlled as some tuners leave it to do the cleaning cycle even if disabled when running and some disable completely duff egr ? |
5th Oct 2014 7:44pm |
Was just meaning that if you cant here it going through the cleaning process could suggest its stuck
5th Oct 2014 7:48pm |
Could be, my last EGR lasted from late 07 to autumn 12.
This one has been from then to now and only 2 years basically. I guess, could I not disconnect it to give it a test and see what happens. I could can clear the MIL anyway if it comes on so that's not an issue. |
5th Oct 2014 7:59pm |
mil light should show (may take a few runs to happen)
5th Oct 2014 8:01pm |
I'll try it.
I'll get it serviced (when they can do it) and get the MOT over with and go from there. If it does turn out to be the EGR it's going to pay me soon to get a remap and shut it off because I can't keep on messing about with it and they costs plenty anyway. I can't be sure but they way it's behaving and the performance iffyness screms EGR issues to me and even more so that I had th MIL the other day. I had a nice day today and it didn't miss a beat but it's a bit annoying that the power delivery is a bit lumpy and not what it should be. Was driving like perfect until just the other day, perhaps some fuel was not quite what it should be. |
5th Oct 2014 8:33pm |
How many miles have you done since your last fuel filter change?
5th Oct 2014 8:37pm |
About 12k, needs doing this month.
I had it planned but clutch went so a bill of £1370 for that meant I had to put it on hold, temporarily anyway. |
5th Oct 2014 8:42pm |
