Home > Puma (Tdci) > Brake vacuum pump leak? |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
get them to fit the latest pump which has a double seal 2.4 90 XS
2nd May 2010 8:41pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
They don't fail catastrophically.
They'll just leak to the point where the seal fails and oil is sprayed around quite a bit. If it isn't obvious (oil on the under side of the bonnet and around the pump itself) then don't bother taking it in - they'll need to be able to confirm the fault before replacing it. Sounds like yours is on the way out - they'll probably be able to diagnose it pretty soon. Make sure the latest part is fitted as a replacement (I doubt there are many of the older ones kicking about now anyway). One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
3rd May 2010 9:43am |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Or spray some old oil all over the pump area... worked for me!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
3rd May 2010 10:37am |
I thought of doing that before mine failed then it obliged and did it for me One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
3rd May 2010 11:31pm |
