Home > Maintenance & Modifications > Mig welder...??
landys1
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Mig welder...??
Hi, got a bit of welding to do on my old series 2 chassis (new front outriggers, new rear cross member!!). Looking to get a mig welder with approx £250 - 300 budget.
Any one got any suggestions as to a half-decent make/model for this sort of money??
Cheers 1959 Series 2 Ragtop
1989 SWB Stationwagon
1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work)
2011 Puma 90 2.4 XS
Post #360973 29th Sep 2014 2:48pm
munch90
something like this , for me would be sealey before Clarke
eBay item number:
eBay Item No. 290406179943
to be honest your not going to get a top make for that budget (kempii , Lincoln, boc, murex etc) your in the sealey/Clarke budget (hobby not professional )
but you can get good results still , good welding is down to good preparation , nice clean metal (more so with mig than stick arc ) get comfortable and something to rest your torch arm on to steady it
don't buy the max amp you can get for the money and stay clean of unknown makes
amps your need at a guess 130-150max this would still good for much thicker than a land rover chassic , don't forget duty cycle will go down as you go up in amps , doubt this would be a problem with amount of welding your do in one weld on a chassic
and if possible get some spare metal the same thickness as your going to weld to get used to welder and get welder set up before you start (might save a few blow holes in weld!) sorry if you know how to weld just trying to be helpful if you don't
Post #360974 29th Sep 2014 3:08pm
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Not my specialist area, but when I was researching R-tech kept being mentioned http://www.r-techwelding.co.uk/Mig_Welder/240V_Mig_Welders Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #360994 29th Sep 2014 3:56pm
Marky Boy
+1 for R Tech - I have one of thier TIG's and it does what it says on the tin. I do use a proper bottle of Argon from BOC though.
Post #361108 29th Sep 2014 9:21pm
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
I have one never used apart from a practice weld. Am i too far away? Cant remember what make it is though or what I paid for it. Like i said its practically new and it would be cheap. Pm id of interest and i can see what it is!!
Post #361147 29th Sep 2014 10:49pm
