Home > Maintenance & Modifications > Fitting a Full Carpet in a 90 |
Wheel Member Since: 29 May 2014 Location: Essex Posts: 232 |
Hi Carl,
How did you get on with your carpet as I'm about to order a new SW 90 XS and LR in their wisdom have deleted the rear carpet and made carpet floor trim for the whole vehicle a £150 option. I've been thinking of looking at options of fitting it myself but tbh it doesn't seem readily available. Have you done yours and what did you decide in the end ? Mark |
17th Sep 2014 12:26pm |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 612 |
Exmoortrim do carpet sets, which you can order in front, rear or full set:
http://www.exmoortrim.co.uk/store/defender...etail.html I went for the no-carpet option as I especially wanted rubber matting in the front footwells, with the option of adding the exmoor stuff to the rear "if needed". However after 1100 miles I cannot see the point of adding carpet, good enough without and more practical too... |
17th Sep 2014 1:12pm |
90XS Member Since: 01 Aug 2014 Location: Shropshire Posts: 76 |
From my own experience I'd definitely pay the £150 and have it factory fitted. Mine came without so I purchased the Exmoor trim kit which is not only more expensive than the factory option, but also a pain in the bum to fit!!
17th Sep 2014 1:19pm |
CarlinAbz Member Since: 15 Sep 2013 Location: Aberdeenshire Posts: 76 |
nothing ordered yet.....I was hoping for some positive comments on here about how easy it was!!! |
17th Sep 2014 1:28pm |
