Home > 130 > Swapping square fog and reversing light for round: snags? |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
2nd pic is UK registered car which will have fog light on the right (off side) as right hand drive. 2005 Td5 90 XS
Steve |
25th Aug 2014 9:44am |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 323 |
Ah I didn't think of that, makes sense!
25th Aug 2014 9:45am |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 208 |
I've done a similar job on my 1990 110, the connectors will be wrong, you'll need 2 of these:http://www.autosparks.co.uk/product_info.php?products_id=1392
There will be fog light and reverse light connectors on both sides so take your pick. The round lights will cover the holes left by the rectangular ones. 1990 Defender 110 200TDI Camper - now converted to Td5 power |
25th Aug 2014 2:36pm |
Great, thanks Hazza!
So I guess I will have to order one of those harnesses for the FOG and one for the REVERSE lights, right? Btw: I thought the square lights were a '130-only thing', never noticed the older 90 and 110 models had them too! |
25th Aug 2014 2:46pm |
The round fog and reverse light were a part of the changes that came out in 2002 ( steel doors,new dash etc). 2005 Td5 90 XS
Steve |
25th Aug 2014 5:11pm |
Yep 1 harness for each (but they are both the same) 1990 Defender 110 200TDI Camper - now converted to Td5 power |
25th Aug 2014 6:39pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
You just need to enlarge the holes drill two M5 holes for the mounting bolts. I get the econoseal connectors off Paul at Lrconnectors on eBay as he's superb to deal with and very helpful http://stores.ebay.co.uk/Land-Rover-Connectors
17th Nov 2014 1:25am |
Ok, I have some good and bad news...
Good: I finally got round to installing the new lights I had lying around for months. I ordered the converter harnesses as per Hazza's post above some time ago, but I found that the new lights wouldn't fit the holes in the mounting plates (I have a 130 HCPU). So I had to order new plates (or modify the existing ones, but new plates are only 10,- each so guess what I ended up doing...). Anyway, life took over and before I knew it, months had passed, but today I wanted to give it a go, but... Bad: the harnesses don't fit the plugs on the car's harness/loom! The harnesses I ordered, do fit the lights perfectly, but have bullet connectors on the other end, whereas the car has these blue sockets that I don't know what they are called: Click image to enlarge The old lights have a connector like this one, that plug in the socket above: Click image to enlarge Are there any converters/connectors I can get that fit the car's blue connector? I really don't want to cut the connectors off and solder/cramp on some improvised connectors. I don't mind cutting off the bullet connectors and solder/cramp on a connector that fits the blue socket, but I have no idea what they are called or where to get something like that! Defender 130 HCPU Td5 MY2000 |
3rd Apr 2015 8:50pm |
Hmmm, thinking this over a bit more, maybe I could simply cut the connectors off the old lights, and solder them onto the harnesses that now have the bullet connectors (cut off the bullet connectors, of course)? Defender 130 HCPU Td5 MY2000
3rd Apr 2015 9:07pm |
Ok, time for an update:
I finally got round to sorting this out. As mentionend in my previous post, I went ahead and cut the connectors off the old fog and reverse light, and soldered them to the harnesses I got, replacing the bullet connectors. Some heatshrink over it, job done. Hooked it all up to the car and everything lit up as it should I do have a follow-up question though: Should the new fog and reverse light be mounted to the car using a seal to sit in between the lamp housing and the body? If so, what part number would that be? I noticed the indicators and rear/brake lights have this seal. My fog and reverse lights came without a seal and I can't seem to find the part number for it!? Defender 130 HCPU Td5 MY2000 |
31st May 2015 9:15am |
Make them. I use butyl pond liner and a scalpel to cut my own gaskets whenever I need them. Available from any good acquatic centre.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
31st May 2015 9:29am |
Hmm, how do you go about doing that? Isn't that a lot of hassle? Defender 130 HCPU Td5 MY2000
31st May 2015 10:45am |
None whatsoever, less hassle than asking for part numbers on a forum, ordering and waiting for something to arrive that costs next to nothing that you can make at home for very little effort and possibly out of better material in very little time.
Draw round object on material, cut out and fit job done and "Bob would be your Auntie if he had them lopped off!" If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
31st May 2015 4:43pm |
Ah, I think I understand now: it is a sheet, not some kind of mastic/caulking? Defender 130 HCPU Td5 MY2000
31st May 2015 4:54pm |
