Home > Technical > Traction control Td5
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
I am trying to work out if the traction control is working on my 110 Td5.
I happened to have one wheel jacked up to ease draining the gearbox but before I did I thought I would see if the traction control was working by engaging drive slowly. The traction control light was illuminating and I could hear it chattering away but I expected the vehicle to try and drive forward but didn't go anywhere.
Handbrake was on mind, but I expected it to at least have it try and pull forward a bit.
Was it working properly?
Post #351445 13th Aug 2014 7:36pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Blimey, that seems a brave way to check the TC..Smile
I'd go and find a bit of loose gravel and try it there. You can also try the ABS on a quiet bit of road.
I did both of these with my TD5 after I changed the modulator and it worked fine.
I'm not sure how much speed you need to have TC kick in, so may not work in your scenario above.
Simon
Post #351451 13th Aug 2014 7:53pm
JWL
You're probably better off trying it out in a cross axle situation, try climbing a large rock without difflock, the traction control should try to brake the wheel/s that are next to leave the ground and you can feel this occouring from the drivers seat.
Post #351453 13th Aug 2014 7:59pm
v8bobber
Not brave really. The wheel was just off the ground and not much in the way of throttle.
I think curiosity got the better of me. I will try and find a crossaxle situation to see if the TC assists in reality but having one wheel artificially off the floor is essentially the same thing.
From having a bit more of a search on t'internet this evening it seems that the TC works better with a bit of revs which makes sense and I wasn't keen to give it a bootfull of revs on the drive.
I will do some more playing.
Dave
Post #351474 13th Aug 2014 9:43pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Your wheel has to be spinning minimal 7 km/hr as I recall right so you need some throttle input before it starts working. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #351491 13th Aug 2014 10:33pm
