Home > Technical > crankcase sensor heat shield |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6265 |
just wondering if anyone is aware of any potential issues with the cc sensor not having a heat shield in place.
mine aint there and gather its not the easiest thing to get at to replace - should I bother? |
7th Aug 2014 3:58pm |
Excellent.....one less thing to worry about..
Looking at workshop manual sensor tells ecm crank position at start up and that's it. |
7th Aug 2014 6:27pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
If you've had a clutch then it will have been left out when the gearbox was refitted, they can be a pita to refit
7th Aug 2014 7:18pm |
Once they've been unclipped they never seem to fit back snugly even if the bracket is tweaked, the one on my last 2.4 rattled and buzzed at high revs.
I see you're still searching for problems ...CV joints ok at the mo? Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
7th Aug 2014 8:51pm |
cv joints!!
Have x2 p2562 faults. Bearing in mind the turbo was replaced I wonder whether the wiring has been the issue all along and it's starting to 'show it's face' so to speak. |
8th Aug 2014 8:27pm |
